I am new to ACA. I downloaded the program online and there was not any check box, or whatever, for downloading the express tools. I go into the computer control panel- programs- to see if it is in there just not loaded. Nope. I cannot find it anywhere. I have purchased this program so there shouldn't be any kind of limitation. Can someone please point me in the right direction? Thanks.
if I right, in instalation wizard You can customize for ACA and choose to install express tools
If You already install ACA, then in COntrol panel -> Add remove programms dialog, You can add components for ACA
Thanks but I did not have an option for installing express tools. Because of that as well it isn't in the add/ remove programs either. It does not reside on my computer, I did not have the option to download it but I do want to have it. Where can I get it from?
in add/ remove dialog you must find ACA, not express tools
when You will be in instalation dialog, You must configure ACA instalation like in video
http://www.youtube.com/watch?v=2fGoZWJmnAw from 0:18
this is for 2013 version, but in other versions that is similar
Yep. Just found that answer. Go to add/ remove programs; find ACA; click on it and wait for it to load; click on "add or remove features"; click whatever check boxes you want including express tools.
Thanks for your help.
It might be that you have installed the Espress Tools but they are not displayed. Try this: in the command line write Expressmenu and then Expresstools then enter.
Usually as soon as you write Expr... a window pops up listing all the commands starting with Expr... chose the two mentioned above.
If the Express Tools has been installed, then the menu will apear and the commands therein will be available. You will lose nothing testing this.
Good luck
