When I use the exportpdf command from within a layout, the resulting PDF is off-center. In the autocad layout, it appears centered within the layout, but when exported it's shifted down and to the left by about half an inch. I can resolve this by changing my page setup from plotting LAYOUT to WINDOW and creating my own extents, however I would like to understand why exportpdf isn't handling layout extents correctly.
When I plot to pdf using Adobe PDF as my plot device, I get the correct layout extents, but when I use the exportpdf command, the layout extents are not correct.
