Hi
I have a problem of exporting from DWG format in autocad architecture to IFC, problem message says (IFCEXPORT System Error encountered during import), what could be the problem?
Unfortunately, there is no way to know what the issue is without the file. If you can share the file in some way (drop box or other method), then I can look at the file. You may also want to try to break up the file into a couple of smaller files and export them seperately if that is an option. Sometimes the size of the file can cause issues.
I've been getting this same issue on a some of my files too. Below is the .log file I am receiving.
[DefaultDomain: ]EXPORT STARTED: 1/3/2014 3:26:05 PM
[DefaultDomain:Error]External component has thrown an exception.
at cppw.Open_model.create(Open_model* , Application_instance* , String* )
at Autodesk.Aec.Ifc.FrameWork.FwPoint.Generate()
at Autodesk.Aec.Ifc.FrameWork.FwFaceBound.Generate()
at Autodesk.Aec.Ifc.FrameWork.FwFace.Generate()
at Autodesk.Aec.Ifc.FrameWork.FwFaceSet.Generate()
at Autodesk.Aec.Ifc.FrameWork.FwBrepSolid.Generate()
at Autodesk.Aec.Ifc.FrameWork.FwRepresentation.Generate()
at Autodesk.Aec.Ifc.FrameWork.FwProductBase.Generate()
at Autodesk.Aec.Ifc.FrameWork.FwElementBase.Generate()
at Autodesk.Aec.Ifc.FrameWork.FwGenericElement.Generate()
at Autodesk.Aec.Ifc.Interop.OpProxy.Export(Boolean generateFwObject)
[DefaultDomain:Error]OpProxy aborting operation...
[DefaultDomain: ]
Object Count:
- AcDb3dSolid : Total: (5)
- AcDbBlockReference : Total: (81)
- MapDesignObj : Total: (1) Fail: (1)
- MapsContainer : Total: (3451) Fail: (2)
** = Object classified as other IFC object.
[DefaultDomain: ]EXPORT ENDED: 1/3/2014 3:34:05 PM
If I need to upload my file, let me know.
