AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Error saving file
1 REPLY 1
surajbliss
222 Views, 1 Reply
Error saving file
Im using auto cad 2010, When i open a file and saving after some edit. When i open after all its starting over (from the bigining) Means my updation are not save. Please help me to solve this problem
1 REPLY 1
David_W_Koch
in reply to: surajbliss
What is the setting for the ISAVEPERCENT system variable? (This can also be found in the Options dialog, on the Open and Save tab, in the upper left corner (File Save area), as the Incremental save percentage edit box.)
If it is not set to 0, try doing so and see if your problems of lost changes is resolved. This will force every save to be a full save, and you will lose some of the speed advantages of partial saves, but there were issues a number of years back with AutoCAD Architecture and partial saves, so we have had this set to 0 ever since.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
”Boost
