Dear Friends
I am using Architecture 2008.
I have a opened drawing which works fine,,,large drawing mainly 3d operations.
When I try to open another drawing I get error 'e06d736h exception at 74a7b727h' which then I have to accept shut it and reopen again.
My pc spec just incase:
Window 7 ultimate 64bit
Proc i7 990x
Memory 12gb 3 channel
Graphic nvidia 460 2gb
All works can modify move copy view zoom, but when click open the mssage above comes.
Have you came across this problem, please help.
Thanks Libaax
Errors like that are often video related. Mess around with different settings on the video acceleration, drivers, etc. and just see what works.
Does it happen when you do the same thing or use a certain command or action? Or maybe while in realistic 3D mode? etc...
Thanks, it looks like the issue went away,,, I set the number of recently opened from 9 to 0 and the shutdown stopped.
Thanks Libaax
