Plase help me with a solution for creating an endcap style for a gypsum board wall, with 2 layers on each side.
I have attached a file showing what the issue is. I want the endcap to be as example numbered with 1.
Can I create a style so that the wall looks like 2 and/or 3?
thank you
Solved by David_W_Koch. Go to Solution.
Its not like this is rocket science anymore. Have you tried the endcap edit-in-place tools? Pretty easy these days to edit an endcap in-place and assign it to a new name if necessary.
1)Read the help files to learn more.
2)Goof around with a file that you aren't worried about messing up.
3)See this video to get started (very short but should give you an idea)
4)I don't know why grips won't work on your station. (Probably not an ACA issue). Try in a new drawing.
Did you turn your grips off? If so, don't turn them off again. Try grips 2 .
Did you turn pickfirst off? I think pickfirst set to 1 is necessary for using some ACA features.
I am not certain why you would want to show the condition indicated for Case "2" or "3" at the end of every Wall (if I really cared about how the different GWB pieces were laid out, I would probably just show a single, typical detail), but I tried to create them, anyway.
I had partial success. The "full wrap" of Case 1 is easy, once you know that you can make a segment of the polyline used to generate the endcap invisible by making it a non-zero width. If you take Doug's suggestion and use the edit-in-place option, you can designate that a particular segment in the endcap profile be invisible.
For Cases "2" and "3" , I was only able to get one side to look the way you want. I thought it might be possible to do what you wanted with overlapping endcaps, but it turns out that when a later component's endcap is drawn over an earlier component's endcap, it hides the crossing line.
In the attached file, I generated the polylines used to create the "5" endcap that was already on the Wall, so you could compare them to the ones I used for the "1", "2" and "3" endcaps. I left a copy of the polylines used for those in the drawing as well. In the sample segments, the "1", "2" and "3" endcaps are applies as instance overrides, not as part of the Wall Style.
Thank you verry much.
I cleared a lot of my issues studiing your drawing. It is clear now how it works.
I have a question though: You drew 5 polylines for the endcap, 4 for the Gypsum and 1 for the component 3 (one segment polyline) Is this polyline needed, it is part of the endcap or is a leftover. I recreated the endcap with only 4 polylines and it was ok.
It remains the issue with edit in place. You can check on the attached dwg the problem. I tried all values for grips and pickfirst but no result. 2 walls side by side, one can be edited, other not. I screw something up when I created the wall style?
I first learned endcaps back when the only method was to do them manually. I suppose even then you would not have had to draw a polyline for any component that was going to be the equivalent of the "Standard" endcap, but I usually draw it, anyway. You are correct in that it is not necessary.
So anybody can give me a solution for no grips for endcap edit in place issue?
thank you
