I am trying to use a pline to create an open ended wall. When I try to 'calculate automatically' by selecting a pline the width of the wall (2 components 8" wide total) the dialogue comes up and asks which component I want to apply the endcap to. I want to apply it to both, but don't seem to have that option. Am I missing something?
Thanks for any input.
Keith D. Rodebush
RA
Solved by David_W_Koch. Go to Solution.
You need a polyline for each component. If your open-ended endcap does not need to create an offset betwee components (along the Wall Length), but just have no linework at the end, you could use the same polyline for each component. (ACA will scale the polyline so that the distance between its start and endpoints equals the component's width. That can cause problems in some endcaps, but should not for a open-end one.)
Thanks David.
I still couldn't assign to two different components at one time but I did it twice, once w/each component and it worked.
I won't fight success at this point....
Thanks for your time.
Keith D. Rodebush
RA
