Whenever i switch to the top view mode, all of my elevated walls dissapear.
Ive set a new level, but the wall still dissapears.
Is there a way to set levels to a layers' state? (for example level 1 layer will showing level 1, level 2 layer showing elevated level, everything layer showing all levels)
Thanks in advance,
Roy
To put a different emphasis on what David said, it is best to model mult-story buildings with separate constructs for each level and to set the level height in the project navigator. Trying to model a multi-story building in a single file is too painful to be productive since you must constantly change the cut-plane heights as you switch between levels. I do not believe the view system accomodates changes in cut planes well either.
