I am trying to make a B.O.M. block which has rows of 1-7/32" array in one direction. When I save the block, close BEDIT, reset the block... It still rounds to 1" array instead of 1 7/32" Have check the units of the dwg and the grip of the block (also insertion and verified all geometry is intersecting properly). The problem is consistent even on making new blocks. Is there some system setting I am not aware of which controls dynamic block unit rounding? Another thing is I have set Chaining action, and have tried increment with Dist min/max... This isn't a pressing matter, but any help is appreciated.
^C^CMoonwalk
