Hello
How do we convert a DWG file in Teamcenter as a dataset to a PDF?
Can we call the PUBLISH functionality of AutoCAD?
you can use the create auxilaury output file pdf in the preference menu.
or Siemens Benelux has a Universal Plot Manager (UPM autocad module)
or wait till december 2013 when Siemens comes with a dispatcher module to create pdf's
You could check the possibilities offerd by the DOC4TC solutions from SEAL Systems :
http://www.sealsystems.com/solutions/products/products-for-teamcenter/conversion/
Best Regards
Can you please share the idea or code on how to convert DWG to PDF in Teamcenter if you got the answer
Thanks In Advance
In 2014 I was looking also looking DWG to PDF translator. But I couldn't find any. I have used two step translation(dwg to dxf and dxf to pdf) as a work around.
