AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Drawing saving with different units
3 REPLIES 3
TherealJD
315 Views, 3 Replies
Recieved a drawing that was originally in imperial. Used AECDWGSETUP to change the units to metric. Everything seems to be okay, but one user opens the drawing to edit it, and the drawing is getting changed back to imperial automatically. Not sure what I should be looking at to stop this from happening. Any suggestions?
Jd...
ACA 2011
3 REPLIES 3
pendean
in reply to: TherealJD
INSERT the problem file into your 'metric' template file and use this newer file instead is one option.
TherealJD
in reply to: pendean
Dean,
Thanks for the idea. I'm only having one user that's having this issue, so i'm thinking it's a setting or something in their ACA setup. I have a few dozen drawings that are behaving that way. They seem to have a couple other odd issues going on, so i've requested they reinstall ACA. If the problem persists, i'll try the insert option and see what happens.
Jd...
tedwardspg
how advaced is the user? do they have a routine in their startup suite that is changing the units to imperial?
ACA 2013
Windows 7 enterprise
Intel core i7 860 @ 2.80GHz
16GB RAM
NVIDIA Quadro FX 1800 - 4GB
”Boost
