Greetings,
Having just recently switched employers I'm trying to get some "old" styles back . One of those was a door showing a double swing. I've never had the need to customize but am in a situation now where I will need to start doing so. It seems as though showing a door with a double swing would be an easy task but I'm not even sure how to start.
Are there any simple tutorials or any suggestions were to begin?
A very easy cheat way to do this is simply add another door over the top. Quick and dirty if it's just a one off. Just make sure it doesn;t get scheduled.
If you mean "double swing" to be say opening 90 degrees forward and back, you can nominate a predefined one in design rules - communicating door.
Change opening % if you want to open more than 90 degrees.
