AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Door Tags Now Have Trailing Zeros
2 REPLIES 2
Impact
384 Views, 2 Replies
We've created our own door tags.  Now in ACA 2013 the doors that have sizes that end in zero (like 3'-0") are showing a zero, a decimal and three trailing zeros in the zero value.  No idea how to fix this.
Anyone?
2 REPLIES 2
leothebuilder
in reply to: Impact
If you have the width of the door showing in your custom door tag you need to change the format of the output from decimal to feet/inches (e.g. change property set definition)
David_W_Koch
in reply to: Impact
To add to Leo's response, the formatting of a property displayed in a Schedule Tag is controlled by the Property Data Format assigned to the property in the Property Set Definition in which the property is defined. (You can override the format in a Schedule Table Definition, but not in a Schedule Tag.) I am not sure why things would have changed in 2013; perhaps you have mixed old, custom content with out-of-the-box supporting content.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
”Boost
