I have created door styles with ADA clearances. My question is that on a couple of them the "push" side could have different clearance options depending on how you are approaching the door, from the hinge side, latch side or straight on. My question is there a way to prompt you for which option you want when inserting the door instead of creating a door style for each option? Guess it would kind of be simular to a dynamic block with options.
