If you are trying to bring in data attached to Spaces in your Door Schedule, and have that data associated with and appear on the same line as the Door, then you do not want to make the Door Schedule apply to Spaces also, as that would only add Spaces to your Schedule, not get the Space data associated with a specific Door.
What you want to do is add one or more Location properties to an object-based Property Set that you attach to your Doors. You will need one Location property for each property you want to read in from your Space. You will need to have both the Door Property Set and your Space Property Set(s) in the drawing file in which you want to set this up, in order to be able to specify the Space Property to be assigned to each Location property.
When a Door (or any other Aec Object) has an object-based Property Set attached that includes a Location property, the object will "sprout" a new grip - a four-sided star attached to the Door origin by a curved, dashed line. Position this grip over the Space to be "read".
Once you have the Location property(ies) reading in the desired datum(a) from the Space, you can then add this(ese) property(ies) to your Schedule Table, and get a Room Name on the same line as all of your other Door data.
David Koch
Using ADT 2004 at work; access to 2005-2009 at home
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
