AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Door Jambs Display in RCP
4 REPLIES 4
dbd63
649 Views, 4 Replies
In the attached image, the left is my 1st floor RCP, which looks the way I want.  The right is my 2nd floor RCP, in which I cannot get the door jambs (orange lines) to turn off.  Cut Planes are set identically in the two dwgs.  I thought the Display Configuration settings were identical in the 2 dwgs, but clearly they're not.  Can you advise?
4 REPLIES 4
David_W_Koch
in reply to: dbd63
Are the two plans in separate files? Can you post sample drawing files that exhibit the problem? If you do, please mention the ACA version you are using.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
dbd63
in reply to: dbd63
First and second floor RCPs attached.  We're on ACA2008.
David_W_Koch
in reply to: dbd63
Took a quick look - the components that are displaying in your 2nd floor plan are Wall Below Cut Plane components.  Not sure why they display in that drawing and not on the 1st floor plan, though.  There are an awful lot of style-level overrides, which multiplies the opportunities for display settings to vary, although I did not see anything obvious tonight.
David Koch
Blog | LinkedIn
dbd63
in reply to: David_W_Koch
Thanks David,
You were right, of course- it was a couple of Below Cut Plane components that needed to be turned off.
”Boost
