Can someone tell me how to adjust the display level on doors.
I have attached a PDF of my problem.
In the sketch is a simple room with 3 types of doors.
A Single door which displays properly
An overhead door which has a sq box attached to it and
A Double door which has all sorts of lines/boxes displayed on it
Ho do I get the doors to appear normal in plan view.
Cheers
For your overhead door, the box attached to it represents the "swing", so if you edit your overhead door style and override the current display representation you can turn off that line (see image1.jpg attached).
For your double door, It looks like your frame, stop, and panel are all oversized. I'd check out the frame dimensions for your door style to make sure those are correct.
If youre still having trouble, try posting the .dwg to help folks track down your problems.
