Is it possible to add an architrave to a door opening automatically.
I.e wall is 150mm thick and door is 1010mm wide and 2100 high. can the architrave go round the edge of the opening and adjust if the door shrinks to 910mm
Thank you
You can carefully craft the components you need for your "architrave", make Blocks of them and then attach those Blocks to a custom Door Style.
See http://www.archidigm.com for examples based on our new Doors 11.0 eParts product for ACA 2011.
Odin Cary
Principal, ARCHIdigm
