Is there a way to preset the reach of the sprout on Location Property Definitions in Property Sets?
For example, I have upper cabinets that aren't over a Space, because there isn't flooring underneath them. Because of this, the sprout reports "Space Not Found" in the cabinet schedule, and I have to go in and manually pull each sprout out until it latches onto a Space.
I would like to set all sprouts to automatically reach out 2'6" from their insertions point. Does anybody know if this is possible? The manual time spent on pulling sprouts off cabinets and electrical fixtures is killing me.
Thanks!
I like Leo's suggestion. You're right. Spaces are probably used by each drafter in different ways. What I was thinking about was keeping track of the total room's square footage. I also use them for clipping ceilings but as you say, you use cathedral ceilings so don't need that. I have heard that spaces can be 3D, not just extruded but have not used that feature much.
I would think that floor finishes would be good to show only in a view drawing but that spaces should be part of the constructs. Using AEC polygons could be another option to applying a floor finish only in certain parts of the room.
