style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<David_W._Koch> wrote in messageNo
href="news:6084074@discussion.autodesk.com">news:6084074@discussion.autodesk.com...
system variable, but I put together an AutoLISP function that toggles the
display of plot styles. The attached ZIP file contains the routine; the
command created is called PST. Since the display of plot styles only works in
a Layout, you get a warning if you try to use it when the Model tab is active.
