AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Display Configurations (Roof Plan)
22 REPLIES 22
Message 1 of 23
cadtastrophe
1200 Views, 22 Replies
I didn't expect this to be a problem, I simply want a new Display Configuration for our roof plans. I would like only walls to show up (no windows / doors / openings). I have created a roof configuration, a roof set and have made sure doors / windows & openings are not checked anywhere yet I still get headers showing (its not a cut plane issue either). Isn't there an easy way to simply say I never want to see doors / windows in a roof plan?
22 REPLIES 22
Message 21 of 23
in reply to: cadtastrophe
mm Thanks Andrew I'll have to investigate that one.
I've been doing alot of live elevations lately so that would suit me.
wrote in message news:5968989@discussion.autodesk.com...
I've accomplished very similar by simply setting the viewport to use the
"model" display for the top view and setting it to plot as "hidden".
Better IMO because it updates real-time.
Andrew
Message 22 of 23
"Revit's method of generating a roof object from a 2-d sketch"
Which is the same way you can create a roof in ADT, from a closed polyline and it is just as easy to modify after.
Message 23 of 23
leothebuilder
After all those years, still no Roof Display settings out of the box or decent way to create a roof plan without work-arounds.
But....we do have a ribbon !!!! YeeeHaaa
”Boost
