AutoCAD Architecture General Discussion
Distinguished Contributor
1bdchristian
Message 1 of 6 (241 Views)
Accepted Solution
Discipline folders
241 Views, 5 Replies
06-05-2012 05:01 AM
could some one tell me what or how the discipline folders where designed to be used with the program. Are they actually used in the program some way or just there for you to manual save things to.?
Thank you  - BDC
The "Disciplines" folder can be used for anything that relates to your project.
(Note that this folder does not appear in the Project Navigator)
You can place other files here that relate to your project, e.g. consultant's plans for various disciplines etc.
You can also add folders for aministration purposes, billing, contract administration etc.
You have the option of not using this folder, deleting it, and create other folders elsewhere to keep these other files.
All depends how you want to set up an office standard.
Valued Contributor
dtdesign
Message 2 of 6 (217 Views)
Re: Discipline folders
06-13-2012 02:30 PM in reply to: 1bdchristian
Are you referring to the folders that are created when you start a project from a template?  Normally, you would create folders for organizing levels and views, etc.  On small projects, I create folders for plans, elevations, details, etc.  On larger projects, I create folders for disciplines as well (i.e. electrical, mechanical, structural, demo, etc.)
1bdchristian
Message 3 of 6 (200 Views)
06-14-2012 06:30 AM in reply to: dtdesign
No I am a ware of creating catagories in the navigator, I have attached an image of what  I am askling. When I create a new project and look in the directory structure and have dicipline folders and not sure how to use them?
thanks BDC
*Expert Elite*
leothebuilder
Message 4 of 6 (195 Views)
06-14-2012 06:45 AM in reply to: 1bdchristian
1bdchristian
Message 5 of 6 (193 Views)
06-14-2012 06:47 AM in reply to: leothebuilder
Thanks - I didn't want to miss being able to use them thru the program.
*Expert Elite*
leothebuilder
Message 6 of 6 (189 Views)
06-14-2012 06:51 AM in reply to: 1bdchristian
The program (ACA) can only see/read autocad (ACA) files.
Mostly we receive consultant's plans in PDF which the Project Navigator would not be able to recognize.
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
