AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Discipline folders
5 REPLIES 5
553 Views, 5 Replies
Discipline folders
could some one tell me what or how the discipline folders where designed to be used with the program. Are they actually used in the program some way or just there for you to manual save things to.?
Thank you  - BDC
5 REPLIES 5
davidtetro
Are you referring to the folders that are created when you start a project from a template?  Normally, you would create folders for organizing levels and views, etc.  On small projects, I create folders for plans, elevations, details, etc.  On larger projects, I create folders for disciplines as well (i.e. electrical, mechanical, structural, demo, etc.)
in reply to: davidtetro
No I am a ware of creating catagories in the navigator, I have attached an image of what  I am askling. When I create a new project and look in the directory structure and have dicipline folders and not sure how to use them?
thanks BDC
leothebuilder
The "Disciplines" folder can be used for anything that relates to your project.
(Note that this folder does not appear in the Project Navigator)
You can place other files here that relate to your project, e.g. consultant's plans for various disciplines etc.
You can also add folders for aministration purposes, billing, contract administration etc.
You have the option of not using this folder, deleting it, and create other folders elsewhere to keep these other files.
All depends how you want to set up an office standard.
in reply to: leothebuilder
Thanks - I didn't want to miss being able to use them thru the program.
leothebuilder
The program (ACA) can only see/read autocad (ACA) files.
Mostly we receive consultant's plans in PDF which the Project Navigator would not be able to recognize.
”Boost
