ACAD Architecture 2011- dimensions are not appearing correctly scaled. How do I scale dimensions and text to correct scale of drawing (i.e., 1/8"=1'-0", 1/2", etc.)?
Make sure that you have the correct scale setting (task bar bottom of your screen) and make sure that
thwe dimensions you are placing are annotative. Also try and select all the dimensions, right click and choose "annotatve" and then select "add current scale".
