Customer Inquiry: How do you modify the database and generate the size of items needed within the software from the Detail Component Database? Can you Adjust sizes? Are there more items to select?
Solved by MichaelBussiere2. Go to Solution.
Thank you for your update/clarification. In this case the issue is that the item from the catalogue can and will need to be set outside of the first entry and/or predefined sizes. When you open up the Detail Database you will select the component and then once selected a list of available components populates in the window pane under the tree of available components. Within this window you will have a list of selectable sizes of that component loaded by the stock configuration. If there are sizes needed outside of this chart you will need to add these sizes in as needed along with descriptions creating new detail components to add to the list. This will allow use in future projects as well.
