After doing a few renders, my drawing now reverts to wireframe every time I close it, save it, regen. Any ideas on how to stop this from happening??. It will basically not stay in 2D wireframe and the dwg has become very sluggish.
Todd
Solved by ntellery. Go to Solution.
Gave up trying to fix it. I just copied everything to a new dwg. Seems to only happen when I render.
Thanks for the link.
Todd
I created this simple list to reset the problem. Yes it only happens when you render because you are using the sky status and perspective and it kinda gets locked in. Copy and past into a text file and name SF.lsp
;;;command to fix the skystatus/perspective/save bug in Acad2011 -should hopefully be fixed in the first hotfix sp1 when it comes out
(defun C:SF()
(command "skystatus" "1" "skystatus" "0" "perspective" "0")
(command "shademode" "2")
