We recently purchased the bldg design suite premium, so we have autocad, autocad mep, autocad structural detailing, and autocad architecture.
By default, .dwg files open with the vanilla autocad application. How can we change the default program for .dwg files to autocad architecture?
Solved by chadcross. Go to Solution.
Right click -> open with does not offer a way to distinguish between autocad / architecture / MEP, only acad.exe.
Are you saying that acad.exe will open as autocad architecture if that was the last program used?
The solution is what you hinted at before.
Let's say I open up AutoCAD MEP then close it. From that point, every time I double click a .dwg, it will open with AutoCAD MEP. Then, let's say 2 days later I open up AutoCAD Architecture then close it. Now every time I double click a .dwg, AutoCAD Architecture will be the default program. It simply uses the last flavor of AutoCAD you launched as the .dwg default application.
Hoping for a solution also as I am having a similar issue. With many AutoCAD versions on my desktop, after double clicking ANY .dwg file it will always open AutoCAD 2017 but I have been using AutoCAD 2018 for months now. I have to open AutoCAD 2018 then select the file through the software but there has to be a simpler way. please post any solutions
@TableThrow wrote:Hoping for a solution also as I am having a similar issue. With many AutoCAD versions on my desktop, after double clicking ANY .dwg file it will always open AutoCAD 2017 but I have been using AutoCAD 2018 for months now. I have to open AutoCAD 2018 then select the file through the software but there has to be a simpler way. please post any solutions
This is a little bit different then everyone else's problem. AutoCAD 2018 does seem to have a different launcher than the previous versions. If you hold shift and right click on the .DWG file and select AutoCAD 2018 as the new default program (may have to check the box to set as default), it should now use 2018 every time. As for setting a default Vertical Application, that is still a pain.
They could have made it a whole lot easier to do that if the 2017 and 2018 icons were different!
But, since the different versions' icons are identical and the DWG Launcher only says "AutoCAD Application", there's no way to see which one you're changing it to.
Yeah, we just loaded 2021 after previously using 2019.
As stated the icons are the same. Even if you get it to open with the right program, it doesn't use your custom shortcut so your profile doesn't load and you get an 'unusable' version.
Not happy.
Keith D. Rodebush
RA
We've got a thread over on the Revit Forum that explains a process for replacing the icons.
Aaron Maller (TwiceRoadsFool) created icons with the version number in the upper right corner & I figured out where Windows looks for the icon
I know this is an older thread but it popped up first in my Google search. I just installed Revit LT 2022 but every time I went to open up a project it would go to 2021. I found this link to resolve the issue:
https://www.asti.com/set-revit-project-default-opening-version/
I followed it and it was super quick and simple and now when I double click my project it opens in 2022. Their installer obviously doesn't update the registry. Hope this helps
This is not correct. I always use Architecture, but if I double click on the file I'm working on Vanilla always starts. I then close Vanilla and then open architecture and have the open the file within that program.
@sjdoornbos Do what the link below suggests after and only after you start the ARCH version you want first, open a file, QSAVE, close the file, close the program https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Double...
If you are still having issues then start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
