when I type in ddinsert (autocad 2014) the dialog box appears as normal, however when I click on browse to select a block or file there is a "ding" noise and the dialog box does nothing further. if I try to insert from the pull down menu, I get the same result. any ideas?
the command line is blank, the autocad program window is normal, the OS is Windows 7 Professional.
The standard library that comes with autocad, and yes it appears that adcenter does indeed work, which gives me a workaround. Thanks!
