I've got the second floor of a building which is an attic, which is over 2 different levels, each of which has its own xref. The roof is sloped. I would like to vary the cut plane in the same view, so that both xrefs are respectively cut at 1500mm above floor level. This would mean using 2 different cut planes, one for each reference. Any idea how to do this?
Just for the record. I think I worked it out. You right click on each xref. Then click object display. Then xref display. Then tick to "override the display configuration shown in the host drawing". It will then use the cut plane set in each xref drawing. 🙂
