Show only
Search instead for
I installed Autocad 2008 with vista business and the crooshair is like floating, is not stable, the mouse is a logitech, and work good in others programs. it is a autocad problem? thanks
I am having the same problem controlling cursor motion and accuracy in AutoCAD 2008 in Vista as you noted in your 9-07 posting. Other than in AutoCAD cursor motion is good. Did you find a solution since you posted your message? Thanks
What! You mean to say that Mr Saadallah's response did not clarify the issue? That is some of his finest work right there and it still leaves you confused? No wonder the man needs a holiday..
Can someone let me know when he gets back? I have an issue i need to be further confused about and a few questions i need answered as vaguely as possible.. 😉
Our firm is finding this problem with AutoCAD Architecture 2008 on the new Dell laptops we have pruchased. It's a serious problem in that it renders our software unusalble. Let me know if you get any luck on a solution. Thanks.
