If I were to guess, I would say the problem was caused by starting a drawing with a Named Plot Style template. The solution for the file at hand is CONVERTPSTYLES to change the file from Named (STB) to Color-dependent (CTB) plot styles. The long-term solution is to use a CTB-based template when creating the file.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
