Can anyone help?
One of my colleagues was creating a drawing today and for some reason all of the walls became corrupt. The drawing is now basically useless and we have to start again. Luckily it has only just been started but it would be nice to know what's wrong. The drawing was created on ACA 2012 sp 2 running on win 7
Many thanks
Ben
Solved by David_W_Koch. Go to Solution.
I had no problems opening the file in ACA 2010. Walls were Walls, Windows were Windows, etc. I ran the AUDIT command and it fixed a spatial index. The attached file is the saved result. Not sure if that will make any difference on your end.
David,
Thank you for the returned file however this is still corrupted for us. We tried to audit the original file but found no errors and you found one, odd!. I've no idea why but we've decided to start again.
Thank you for all of your help
Kind regards
Ben
