We are copying our original files to a sub folder to make revisions that have only happened after bidding. We want to keep our original bid documents intact. I have created a sub folder called 'Conformed Documents' and added Constructs, Sheets, Elements, ect.
I copied the files over and used the Reference Manager to repath the files. However, all of my schedules and room tags now use the 'NA' prefix because it is not reading the project information. How can i reconnect this folder to the project folder?
Solved by dbroad. Go to Solution.
If you used the project navigator to build your project and want to archive it, you might try etransmitting it(to yourself). It should be able to be unpacked to another folder without much fuss. The etransmit process takes care of the housekeeping chores of keeping references and links straight.
