wrote in message ...
>And we all know that when you do a save-as, other versions will sometimes
>change the font.
That only happens if the "other version" doesn't have the same fonts that
your version has. That has nothing to do with "different versions", because
the same thing can happen between two installations of the same version.
I've never had the font arbitrarily change between version if both
installations have the same set of fonts (shx and/or ttf) installed.
Can't help you with layer states - I don't work with that very much.
