AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Complex wall style
5 REPLIES 5
BobbyDDD
301 Views, 5 Replies
Complex wall style
Hi!
How can i create this one complex wall style?
Thank's
5 REPLIES 5
Lquinones
in reply to: BobbyDDD
You can create a wall with 3 components and 1 endcap style applied to the star and end of the wall.
I hope this help. I hope this help.
The end cap material could be a 0 or very small width componant that you
adjust it's end cap to display at the ends.
(not sure how you would grab the end cap of a 0 width componant).
wrote in message news:6278332@discussion.autodesk.com...
BobbyDDD
I've attached the base file.
Didn't work with a 0 width componant so I made it a small amount (0.1mm)
Note the widths are not what you ordered but that can be changed to order.
You will probably have to then adjust the endcap but that's easy.
Just select the wall and right click and 'Edit endcaps' and adjust the
endcap to suit.
Boy that is easy in 2010.
"Nathan" wrote in message
news:6278488@discussion.autodesk.com...
BobbyDDD
>Nathan
Thank you very match!
It was just great!
”Boost
