I have created a 30 page 8.5 x11 booklet, using Architecure 2012, for a campus mater plan. Now our priciples want to see it in a hand sketch format. I can do the lines with the visual style sketchy but how do I get the solid hatch colors to look like color pencil? I am assuming I will need to use Photoshop but just wondering if there is something I can do in Autocad Architecture.
Kory Skoog
CADD Technician
Solved by igroup.kskoog. Go to Solution.
If you're on subscription you should have access to Autodesk Impression. It will import autocad files and do what you want.
John
I downloaded Impressions 3 for Windows 7. I try to import and I get an error message saying drawing file is invalid. I have tried on other .dwg files and get the same message. Using Autocad Architecture 2012. WHat am I doing wrong?
Kory Skoog
CADD Technician
I suspect it only accepts non-AEC DWG files: -EXPORTTOAUTOCAD and try again.
I tried it but still gives me the same error message.
Kory Skoog
CADD Technician
There is a hotfix for it, did you install that?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14719247&linkID=9243223
Yes. I installed it and followed the "Crash on Windows 7 Hotfix" text file. My thinking now is to unistall and install the program and do the Hotfix.
Kory Skoog
CADD Technician
Ok I figured it out. I had colors from the True Color palette. Impression does not accept them. I changed my colors to the Index Color palette and it worked. Thanks for all your help.
Kory Skoog
CADD Technician
