Hi. Brand new to Autocad so this is probably a very simple problem. I have a 2d drawing that I have open in Autodesk Architceture 2015. All the layers are unlocked and thawed. When I click on a line it selects the whole drawing. Could someone tell me what I need to do to just select certains lines or objects? Thank you so much for the help.
Most likely, either everything in your drawing is nested within a single block reference (or a single external reference) -OR- everything in your file is part of a single group, and you have PICKSTYLE set to select all objects in a group when one object is selected.
For the latter, setting PICKSTYLE to 0 or 2 will deactivate group selection. (0 deactivates associative hatch boundary selection as well; 2 preserves associative hatch boundary selection.) For the former, if an external reference, you could just open that file directly. If a local block reference, you could edit the block in place or (YOIKS!) explode it. I would be very leery of exploding the block, and would check with your co-workers/supervisors (if you have any) before doing that.
