I've successfully installed AutoCAD Architecture, and others, and was wondering if the files created directly in my C: drive under the folder 'Autodesk' can be deleted, (running short of disk space)?
They look to be, by their names, install files and I note what looks to be the actual applications, etc., are present in the Program folder, under another Autodesk folder, and Program (x86) for Design Review.
Solved by pendean. Go to Solution.
You can delete that folder: but if you are running out of space because of a 2Gig install folder you've got bigger problems that will hit you pretty quickly. Start planning for a new HD upgrade soon.
