AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Civil and Architectural Scales
3 REPLIES 3
chughes
2346 Views, 3 Replies
How can I have the option to select either civil or architectural scales for annotation and viewport scales?  Currently I only have architectural scales. Some projects have the site plan at a civil scale, so I need the option.  Hopefully this is simple setting that I am missing, as this solution will need to be deployed firmwide.
Thanks.
3 REPLIES 3
David_W_Koch
in reply to: chughes
Edit your drawing template file(s) and use the SCALELISTEDIT command to add/delete scales. (Can also be found via the ribbon: Annotation ribbon tab, Annotation Scaling panel.)
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
chughes
in reply to: David_W_Koch
Thanks for the response David.
I assume that I would just need to manually add in the Civil scales in the template.  There is no checkbox (for example) that would bring them all in.
David_W_Koch
For future drawings, getting the scales you want in the template file(s) would be the way to go.
To  add those additional scales to existing drawings, create a file from the template after you add the scales and add a piece of annotative content to that file, adding all of the custom scales to it.  Save the file, then use the INSERT command to insert that file as a block into a file to which you want to add the scales.  You can then delete the inserted block and purge the block definition; the custom scales will remain in the drawing.
David Koch
Blog | LinkedIn
”Boost
