AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Change window size
4 REPLIES 4
stew
6628 Views, 4 Replies
Change window size
Sometimes when we place a window in a wall we can grab the grip and stretch it to any size we want. Other times the only sizes we can use are the standard sizes. I know how to add a standard size but how can we make it to where you can just strectch it to any size we want?
4 REPLIES 4
jcp
in reply to: stew
When a window style has standard sizes apply it removes the ability stretch to any length.  The only way I am aware to make a window infinitely stretchable is to remove all of the standard sizes from the style.  Alternatively you could make a copy of a window style, remove the standard sizes and apply that style to any windows that needed the infinitely adjustable sizing.
David_W_Koch
in reply to: stew
When you place a window with standard sizes and want to stretch it to a non-standard size, when you make the width grip hot, you will see long gray lines indicating standard widths, if the current width is a standard width, and short red lines indicating standard widths, if the current width is non-standard.  The initial state locks you into standard widths, but by tapping the CTRL key, you can toggle to dismiss the lines and stretch to a non-standard width.  No need to create a parallel style with no standard widths.
If you have grip tips activated, you can get a reminder of this by hovering the cursor over the width grip without making it active - see attached image.  (Activate grip tips in the Options dialog, on the Selection tab, in the Grips area by checking the toggle.)
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
David_W_Koch
in reply to: David_W_Koch
Had a little free time today, and made a blog post on grip editing of styles with standard sizes.  If you are interested, you can find the article here:  http://architects-desktop.blogspot.com/2012/09/aca-grip-editing-of-doors-and-windows.html
David Koch
Blog | LinkedIn
stew
in reply to: stew
Thanks David
”Boost
