Thank you Dean. That is correct and will allow adjustments to the dimension (leaders) styles. Additionally you can use the QLEADER command and then select “S” for settings. This will then populate the QLEADER dialog box for additional adjustments. Please let us know if this helped resolve this inquiry and/or if we can mark this as solved. Thank you and we look forward to your reply in the community.
Additionally other users who may be looking for adjustments for MLEADER versus the above please use the MLEADERSTYLE command. This will then enable the style dialog box to then select “modify” current style or create “new” style. From there you can then follow through the tabs for adjustments specific to the MLEADER.
