AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Change default Arrow Head size for leader
3 REPLIES 3
ljhudson
57574 Views, 3 Replies
this is for a leader & quick leader only... not the multi-leader..
How can I change the default arrowhead size from 3/32 to 5/32... I am able to change it from the palettes only after I insert it.
I would like to have all leaders of all styles match the same style far as arrowhead size... multi-leaders are defaulted as 5/32 and after using them forwe like them this size verses the 3/32 size of the quick leader
3 REPLIES 3
in reply to: ljhudson
Leader and Qleader settings are part of your DIMSTYLE settings.
Dean Saadallah
http://LTisACAD.blogspot.com
MichaelBussiere2
Thank you Dean.  That is correct and will allow adjustments to the dimension (leaders) styles.  Additionally you can use the QLEADER command and then select “S” for settings.  This will then populate the QLEADER dialog box for additional adjustments.  Please let us know if this helped resolve this inquiry and/or if we can mark this as solved.  Thank you and we look forward to your reply in the community.
Michael Bussiere II
Support Specialist
Product Support
MichaelBussiere2
Additionally other users who may be looking for adjustments for MLEADER versus the above please use the MLEADERSTYLE command.  This will then enable the style dialog box to then select “modify” current style or create “new” style.  From there you can then follow through the tabs for adjustments specific to the MLEADER.
Michael Bussiere II
Support Specialist
Product Support
”Boost
