AutoCAD Architecture General Discussion
New Member
IlIOsirisIlI
Message 1 of 3 (499 Views)
Ceramic Tile Help
499 Views, 2 Replies
03-27-2012 12:59 PM
I work for a Ceramic tile contractor I have had little training on cad. I am being forced to make some shop drawings for a project showing how tile will lay out exactly in a restroom walls and floors.  Can anyone direct me to a video or guide to show how to use cad for tile installation layout.  Thanks.
Valued Mentor
KathyMoffa
Message 2 of 3 (488 Views)
Re: Ceramic Tile Help
03-28-2012 08:03 AM in reply to: IlIOsirisIlI
Are you using AutoCAD Architecture, and if so, what version?   If you have no need for a 3D presentation that shows the actual tile being used, and are strictly looking for a layout for the pattern, the easiest way I know is to draw separate polyline outlines of your floor and wall, using the exact dimensions, then use the Hatch command to fill in the areas with a tile pattern.   The hatch command is found in ACA by entering Hatch from the command line and on the Home/Draw tab on the ribbon.
*Expert Elite*
MarySeufert
Message 3 of 3 (486 Views)
03-28-2012 08:09 AM in reply to: IlIOsirisIlI
Watch the vieos from the help menu within AutoCAD (Press F1). Go through some of the tutorials that come with it. Check out YouTube - there are a lot of videos on AutoCAD. You could also check out various books for learning AutoCAD on your own.
Here are some good websites that have tutorials/vidoes to check out:
Cad Tutor
CAD Corner
Draftsperson
JTB World
Good luck ~ Mary
_______________________________________________________________________
Normal people believe that if it ain't broke, don't fix it.
Software Engineers believe that if it ain't broke, it doesn't have enough features yet.
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
