I manage my building drawings using a MS Access database, I have since 2002. I am currently running AutoCAD Architecture 2012. When I search for a drawing in the database, and click on a hyperlink to the file, Architecture opens the file just fine. No read only status in the top bar on the Architecture window. I can work just fine, but when I exit the file, I get no option to save. It just quits. When I open the file again, from the operating system (double click on the file in the folder) it is just as I found it before the attemped editing session.This had worked fine for years.
@Anonymous wrote:
Pan and Zoom commands are not seen as "drawing Edits" that "require" a save to keep.
AFAIK, that is not correct. AutoCAD sees pan and zooms as an edit to the drawing.
To the OP; have you tried user forums for MS Access for help? I've never come across this kind of issue on these forums...
A system variable to try out is ISAVEPERCENT, setting it to 0.
@Anonymous wrote:
@Anonymous wrote:
Pan and Zoom commands are not seen as "drawing Edits" that "require" a save to keep.AFAIK, that is not correct. AutoCAD sees pan and zooms as an edit to the drawing.
Sorry Mary but that belief has burnt me more than once.
The DBMOD system variable stores the bit-coded values to indicate weather or not to prompt for save on closing. There are seperate values for:
1 = Database modified
2 = (removed)
4 = Database Variable Modified
8 = Window (size) modified
16 = View Modified
32 = Field Modified
Depending on how you opened a drawing (double-click on a file to open the drawing and AutoCAD, drag a file onto the AutoCAD icon to launch and open, launch AutoCAD then use the "open" command, etc) and how you close the drawing (use the Close command, hit the "x" for the drawing, Hit the "X" for the application, Exit or Quit the application and let that close the drawing, etc) different flags and variables are taken into consideration when exiting...
They have gotten better over the years (ie if dbmod > 0 then prompt to save) but some combinations (to help allow for automation perhaps? I don't know the reason) will ignore the bitflag values of 8 and 16 when checking to see if the drawing has been saved and therefore prompting for save on close...
I've supported literally hundreds of users on a direct one on one basis, gotten to know their habits... I had to to help determine why this failed or that failed or "yesterday this worked but today it doesn't"... And I've learned the hard way...When your livelihood depends on it, Trust in yourself, not the application...
Type "Q" before you close a drawing, and often while you're in it... easiest thing in the world to overcome the possibility of losing work...
So I stand behind both of my statements: Sometimes AutoCAD will ignore pan and zoom operations when determining if a drawing qualifies as having been edited and Manually save the drawing instead of relying on a prompt to remind you to do it.
-Gary
Just for S&G I've opened the same exact drawing in multiple ways, read the value, executed the pan command, and then attempted to close the drawing every different way I know...
Drag to ACAD icon - DBMOD=0; after executing pan command DBMOD=20; result prompts for save.
Quick access bar Open - DBMOD=0; after executing pan command DBMOD=20; result prompts for save.
Selecting from recent opened drawings from app menu - DBMOD=0; after executing pan command DBMOD=20; result prompts for save.
App Menu open - DBMOD=0; after executing pan command DBMOD=20; result prompts for save.
Double picking from windows explorer - DBMOD=0; after executing pan command DBMOD=20; result prompts for save.
Wow all the values are exactly the same! I expected some of the initial values to be different. So I'll also stand behind my statement I was even reading a recently revived thread the other day, were the complaint was that AutoCAD doesn't ignore pans and zooms like a lot of other graphics programs. Maybe back in the day your observation was correct, but I can't verify it in the here and now. By the way 'Q' is an undefined command OOTB (2012).
The OP has a special environment that he is working in which perhaps has some odd things going on. It would be interesting to know what the DBMOD value is when opening from MS Access.
Hi Donald,
Does the issue still occur if you launch the program first, and then select the hyperlink to open the drawing?
What if you manually save the drawing, instead of clicking the X and waiting for the prompt to ask you if you'd like to save?
