I cannot draw any elements from design pallet. Happens suddenly. Probably I accidentally switch something. In command line show command like:WallAdd and right away show another command line. Cannot add any doors or windows - same problem.
Try using the command line:
WALL -----add
DOOR----add
etc. etc.
If the commands work it propably a problem with the tool palette
Does anyone have a fix for this problem? I am experiencing the same problem. Reinstalling and repairing doesn't resolve the issue.
Which version of Autocad Architecture are you using?
Are you using tools from the Home ribbon?
Are you using the tool palettes?
Or are you using the command line?
I am using the Tool Palette-Design in Architecture 2012, and none of the XXXXADD commands work.
I also tried just the command line entry, which didn't work either. If I draw a line, I can apply the wall to line work, but that is it. Even at that, I can only select the wall, but there are no properties listed for it.
Have you checked your profile (Options/Profiles) and made certain that it is set to AutoCAD Architecture and not vanilla AutoCAD? Both install with the software.
Yes, and actually, I tried switching between the two, trying the walladd command after each switch.
Since neither a reinstall nor a repair solved the problem, you may need to do a complete uninstall using one of the registry cleaner tools like Revo Uninstaller.
