I have just taken the plundge into windows 10, it all looks very shiney and new!
The problem is, i can't open or save any of my cad files. I am running Autocad LT 2016. Every time i open a drawing i get a message that tell me the file is read only. if i try to save the file i get a dialog box that tells me i don't have permision tosave in this location. My profile is the administrator on my machine.
For some reason all of my cad files are now read only. If i change them to read write they revert back to read only!
Any ideas?
Thanks in advance .
Solved by register. Go to Solution.
Autodesk products are not supported on the Windows 10 platform. Plenty of other posts about that subject.
Cheers Keith.Brown
I have tried removing the read/write permission with no luck.
I have however discovered that if i copy the file to a memory stick it will open without any problems. Temporary fix hopefully!
