AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Can't Open AutoCad 2011
2 REPLIES 2
RAYCOX5805
267 Views, 2 Replies
I am running AutoCad 2011 32 bit and suddenly, for the first time I can't get it to open.  I have run Repair and Reinstall, and all sorts of diagnostics to no avail.  Can anyone provide me with a solution to this problem?
Ray Cox
2 REPLIES 2
pendean
in reply to: RAYCOX5805
did you try simply restarting your pc when it first happened?
or a Windows System Restore?
this started mid workday, or has there been an overnight or more time between now and when it last worked? or did you install or uninstall or upgrade or downgrade something on that PC?
samuelwilliam
which OS are used ?your system fullfill the requirement are needed to autocad 2011.
”Boost
