Can a sheet set itself contain AEC data, where a reference via a field to any element within the sheet set would cause AEC modules to load upon opening a drawing?
Could you elaborate on the intension for this feature?
Nothing like bumping a 3 year old thread but.....
It's not a feature I'm interested in. If I recall correctly, I was having an issue with keeping my files clean of AEC content. I had one sheet that was causing AEC modules to load becuase of a field reference.
Example: "File A" was clean of AEC content. "File B" was infected with AEC content. A field existed in "File A" with a reference to a view in "File B". So each time I opened "FIle A" the AEC modules would load even tho the file itself didn't contain in AEC content.
Edit: I have no idea why this thread was moved to the Architecture forum. This was/is a vanilla AutoCAD issue.
Once a file has AEC content in it, it is pointless to try to clean it out in my experience. I used to worry about it and then just accepted it.
I agree it is very difficult to deal with. I can't bring myself to just accept it. If I did, eventually all my files would be infected.
I'm still wanting something along the lines of the EDU warning for AEC content. At least I'd have a better chance of keeping files clean.
There is always EXPORTTOAUTOCAD to clean them up...
Edit: perhaps sheets sets created by ACA's PN will have AEC content activated whether or not it is present...
@Anonymous wrote:There is always EXPORTTOAUTOCAD to clean them up...
Yeah there is that option, but that also destroys existing field references to the sheet set and sheet views.
I'm a vanilla user, so the AEC content had to of been added in some other fashion.
Mary,
I would have suggested export... but somehow, stuff sometimes creeps back anyway. I generally just accept the few seconds that is required by the additional module loads and forget about it. Frustration level dropped and it really didn't matter much anyway.
