Hellow everyone!
I use Autcad Architecure 2010 on my computer.
After I created or made a multiline text, the ribbon in autocad is getting all blurry. None of the icons in the ribbon will work (see attached picture).
I always have to shut down Autocad and restart it to continue my work.
Can anyone give some advice wich fix this problem!?
Thanks in advance!
Solved by David_W_Koch. Go to Solution.
Do you have both the ACA.cuix and the ACAD.cuix loaded at the same time? Both contain contextual ribbon tabs that are tied to the same event, and when both try to initiate at once, the ribbon will freeze. You need to either only load one of the CUIX files at one time, or you need to take the one you are using as a partial customization file and eliminate all of the contextual ribbon tabs that overlap those in the main customization file. If you are interested, you can read more about this in this blog article.
Thank you for the advice! This was the solution I was searching for a long time!
