I just got a new computer, and installed autocad 2015. I have opened a dymamic block in the block editor, and tried to add a "Block Properties Table" from the action toolpallet. Usually when added, the table shows up and you are able to add information to the table. This is not happening. I seems to open, but not visable. You have to hit ESC to exit out.
Can anybody help?
Thanks in advance.
Hi Troy,
Thank you for posting. I'm sorry to hear you're eperiencing this issue. Could you please confirm that when you double-click the Block Properties Table, this is the dialog box you're expecting to see, but it is not popping up for you?
I'd also like to know:
Yes, that is the box that I am expecting.
Yes, all the others seem to work correctly. Visibility states, Property Boxes seem to be working correctly.
I did not have a previous version of AutoCAD to pull from. I have attached a current profile.
I have made changes to the profile, pointing to different locations. I tried to see if the “Unnamed Profile” work, and It did not.
I changed my User account to “Never”. It did not work.
I have reset and reinstalled my software multiple times.
I might be a video driver issue.
Hi Troy,
Thank you for attaching your system information.
Before I make any suggestions regarding your graphics card, I'd like you to try the suggestion in this article (especially if you've ever used more than one monitor with your machine):
Dialog windows do not display in AutoCAD and the program appears to freeze
If that doesn't bring the dialog box back into view, and you're running the program on a laptop with dual graphics cards and/or Direct X 11 (it looks like you might be), you may want to try the suggestions in the following articles:
AutoCAD crashes when opening or closing drawings on laptops with dual graphics cards
AutoCAD uses the wrong graphics card
How to make AutoCAD run with DirectX 9
You may also want to install the certified driver for your graphics card, and ensure you've installed ACA 2015 Service Pack 1:
NVIDIA Quadro K1100M 9.18.13.3311
